Attention e60 530 owners, this could be important!!!
I posted recently about my experience with a rough idle and several error codes here:
https://5series.net/forums/e60-discu...alling-128763/
I have a 2005 530 (M54 engine), and it appears that the issue resulted in a total of 4 pages of error codes including: misfire in nearly all cylinders, O2 sensor errors, Secondary Air Pump errors, MAF errors, Catalytic Converter errors, and Engine Malfunction errors. Needless to say I was freaking out, how do you begin to diagnose so many codes (and how much is this going to cost me?).
It turns out the problem is just a vacuum line low on the driver's side of the engine. I took the car to a friend of my father-in-laws who used his diagnostic computer and saw all these errors, again, 4 pages worth. Then he listened to the engine running really rough at idle, with RPMs jumping 5-600 (from 700 to 200 and back, sometimes stalling). Then he reached down the side of the engine and held the vacuum line together and the motor INSTANTLY started purring like a happy kitten. Turns out this vacuum line causes all these errors and the rough idle. So before you spend copious amounts of money trying to replace coils, O2 sensors, air pumps, etc, check this vacuum line. Hopefully this thread saves someone some major cash. Good luck.
I will update this thread with a pic of the offending part if I can, I should get my car back tonight. The total for the repair? $75, including his labor. I am VERY relieved.
Wow. He saved you a boatload of benjamins! Nothing beats a seasoned mechanic with old school experience. Good for you.
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
Some good info here. It's about the M54 and M52 engines. Same M54 as the E60 530i.
Cold weather misfires and CEL, common issues $50 fix! - E46Fanatics
My Ride: 07 530i Mystic Blue
Thanks for sharing John. Glad to hear that it was a minor fix. I'm sure you must have had a mini heart attack when you reviewed all the codes. I sure would have. Lol.
Your father-in-law's friend must be quite knowledgeable about cars to detect the problem that easily. I may have to reach out to you in the future and ask you for his info if I have any issues. Thus far, my car has been running great and hoping that it stays that way.
Enjoy your newly modded E60 again!
- Jason
- Jason
