Sponsored by:
Sponsored by:
Radiator kills the water pump
Old 04-09-2018, 04:59 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default Radiator kills the water pump
We have a 2010 e60 with a N52k.
Any owner removing the radiator for any reason, pulls out the radiator and the bottom 33% of the radiator is blocked from leaves and dirt. When the radiator is pulled there is a massive amount of leaves that come out with it.
If the bottom 33% of the radiator is blocked, is it logical to think the electric water pump now has to work 33% harder to cool the engine?
If the electric water pump is overworked, is this the key reason that the majority of BMW electric water pumps fail prematurely?
Old 04-09-2018, 05:47 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
The short answer is no.
The pumps are designed to handle coolant at the temperatures that are present. The area of the radiator does not affect the performance of the pump but the temperature of the coolant. When the area is not large enough to cool the coolant sufficiently, then the temperature rises, but not higher than the design temperature of the pump. The pump will, however, be pumping at maximum flow, but the pumps are designed for that too. Non electric pumps always run at max flow and the temperature is controlled by bypassing the radiator. I believe that the electric pump motors are probably under sized electrically and suffer electrical failure because of that.
lcc014
01-19-2017 07:54 AM
znod
07-19-2006 05:07 PM
550i2NV
The Competition
66
05-02-2006 06:19 AM
wolverine
E60 M5 Discussion
21
04-05-2006 11:28 AM
stream
Lounge
10-09-2005 01:07 AM
Quick Reply: Radiator kills the water pump
