Assistance needed...
Yesterday the FTM went off and I pulled into the nearest station and checked tire pressures and found the left rear to be at 20psi - could not see anything - so I filled up to the proper psi and went on my merry way.
This morning I get another FTM warning and pulling in my neighborhood Exxon and check the left rear - again down to 20 psi - except this time I see a rather large screw!
So I come home and leave the car in garage and when I got home tonight I proceed to "try" and remove and can't
So I place a call the Roadside Assistance and 30 minutes later the dude shows up and we get the rim off....
now the shocking part, the inside edge is horrible worn and in about 5 different places the sidewall is starting to split
- boy am I glad I got the screw.
![Assistance needed...-p4060479.jpg](https://5series.net/forums/attachments/e60-discussion-2/17464d1482364092t-assistance-needed-p4060479.jpg)
note the inside tread on the right side of the tire in the picture...
![Assistance needed...-p4060480.jpg](https://5series.net/forums/attachments/e60-discussion-2/17465d1482364092t-assistance-needed-p4060480.jpg)
I have circled the "splitting"
![Assistance needed...-p4060484.jpg](https://5series.net/forums/attachments/e60-discussion-2/17466d1482364092t-assistance-needed-p4060484.jpg)
notice the "arrow" point to the "dip" in the tire as you view from left to right...
So, can someone please explain this wear pattern? Over inflating would have resulted in the middle wearing quickly and under inflating would have both outer sides wearing....I am at a loss for words!
Some of you will know that I have complained bitterly about the Bridgestones and will go back to the Michelins like on my M5!
TIA,
Cheers.....
![Mad](https://5series.net/forums/images/smilies/mad.gif)
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
TIA,
Cheers.....
My Ride: G30 M550i
Model Year: 2018
My guess is underinflation. I realize that normally you'd expect the outsides to wear if a tire is underinflated but with the negative camber of the rear wheels on these cars, the inside will wear more than the outside...
My Ride: 2004 520i, mystic blue, steptronic, beige leather, pdc, bluetooth, rain sensor, BMW sport kit fitted, 18" 166 rep BMW rims , de-badged, cherished reg. chrome grill,
Attachment 17464
Attachment 17465
Its not balance its ALIGNMENT you don't experience anything in the cars driving buts thats the problem if you had it lowered that would be the reason
Attachment 17466
TIA,
Cheers.....
Attachment 17464
Attachment 17465
Attachment 17466
TIA,
Cheers.....
sorry, the mileage is 17,300.....
I stopped by NTB this morning and showed them the tire and they suspected alignment as well. I am pretty good about checking inflation, so I would be surprised if that were the case - but you never know!
So, my next questions is how does the rear become un-aligned?
A modern radial tyre can practically not be overinflated.
One should always have a bit more pressure in the tyres
than the manual says.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Ricracing' post='265903' date='Apr 7 2006, 10:26 AM
I'm with Rudy here (once again).
It looks like an alignment issue. However I have to comment on the "you can't over inflate modern radial tires" statement. I used to club race a 911 and the one thing that made the most significant difference in performance was tire pressure. Two lbs. front or rear made the car handle substantially different. Something to conceder.
Look here for a simple explanation of wear problems:
Dunlop Tyres
You clearly have a problem with camber or alignment.
Wear SHOULD be even accross the surface of the tyre.
Dunlop Tyres
