asking for a friend wheels on an xi model
My Ride: 2010 BMW 550i m sport lci
2008.528xi can you put a staggered set of a 550i without hurting the drivetrain or handling? Thank you ahead
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
No they won't negatively affect the handling or drivetrain. The problem you will encounter is the offset. If they are off of a RWD 550 the offset is too low, they will rub.
There are some finer points. You can have a staggered setup, but the tires must all be of similar rolling diameter. If they aren't you end up with two problems. First, just like messing with tire sizes can mess up the speedometer, they can also mess with ABS, stability control, etc. Second, there is a transfer case. Differing rolling diameters will cause the transfer case to work harder that it is designed to work.
The 2008 owners manual is in the INFO section of this site. The manual specifically allows the following set ups. Using the tire calculator http://www.discounttire.com/dtcs/infoTireMath.do I get the following:
245/45 R 17 - 785.33 revs/mile
225/50 R 17 - 779.95 revs/mile
245/40 R 18 - 784.25 revs/mile
front: 245/40 R 18 - 784.25 revs/mile
rear: 275/35 R 18 - 788.47 revs/mile
As you can see, the staggered setup is about 4 revolutions per mile different from front to rear.
socale39
09-05-2023 08:30 AM
carid
04-10-2015 01:59 AM
