Anyone know where the location of the fuse for "Comfort Access
I search everywhere but can't find anything on how to the disable comfort access...does anyone know if its possible to disable just the comfort access? is there fuse where I can pull out? if so where? Thanks.
My Ride: 2010 535i xDrive, Space Gray Metallic, Gray Dakota Leather, automatic, comfort access, window shades, comfort seats, fold down rear seats, PDC, Navi, HUD, HD Radio, premium package, value package
You don't state the build date of your car (fuse box changes depending on year)
Rear fuse box near battery
F51 - Alarm, Comfort access door, electrochromic mirror
F53 - Comfort Access, Outer door handle electronic modules (build 9/2004 - 9/2006)
Front Fuses (behind glovebox)
F36 - Comfort Access control module, outer door handle electronic modules
This is from Bentley Manual vol 2 starting on page ECL-21
It's 2008 550i
Ok so thanks ssmokn it is the front fuse 36, I pull it off and CA is disable now. I'm 90% sure that the "high battery drain" error message is related to the CA door handles or module.
I plan to just unplugging each CA wire to all the handle and plugging one back in at a time. This process will take a about a month since the error only show up after I let the car sit for more then 3 days...so does anyone know if theres a quicker way to find out which handles? I'm an newbi when it comes to electric stuff.
spykes
07-10-2015 07:49 AM
