Anyone have/use Auterra Dashdyno SPD?
My Ride: C32 AMG fully modified - 535i Sport, work in progress
Does anyone here run an Auterra Dashdyno SPD? I previously had this hooked up to a C32 AMG and it worked like a champ. Was a great way to track modifications with "estimated" hp/tq, 0-60, data-logging, etc. Once properly setup, it proved to be very accurate verified on a Mustang Dyno.
Anyway, on my 535 I can data-log most items with no problems, but the generic dyno run is way off. Did a quick run and it had me at 450+hp and some ridiculous 1000+tq. Obviously the numbers I used to set the parameters aren't accurate. Here is an example of the parameters I am in need of - If anyone has a setup file (or parameters) for me to copy, it would be greatly appreciated! I can go look at the numbers I currently have plugged in to compare if that would help. All numbers used were OEM specs I found online, but something clearly isn't right.
Car specs: 2008 535i sport with stock 18" rims - all stock...for now. BMS intake and JB4 on the way.
