Anyone experience noisy brakes at low speeds on their 550?
My Ride: 07' 550i sport; Sapphire Black/Auburn; sport package; steptronic; navigation with R.T.T.I.; heads up; cold weather package; Logic-7; BMW MOST ipod kit; Motorola V3 snap-in adapter; rear heated seats and rear shades; anthracite headliner; sirrius sat. radio; M-aero kit; OEM style 166 Wheels with 245/35-19 front and 285/30-19 rear Michelin PS2s.
I brought my car in for service this week because the brakes were grinding/squealing from around 10 mph down to 0. The pads weren't worn and the brakes were fine under all other circumstances. I read about a known issue with the front wear sensors contacing the rotors and mentioned it to my SA. The work order indicates that the front pads and sensors were replaced. Here's the problem: 1) the low speed grinding is still present, although it may be coming from the rear axle which was not looked at while the car was in service? Also, now that the new front pads and rotors were renewed there is a bad rubbing/ringing noise when turning the wheel at parking lot speeds - without hitting the brakes! I am hoping that whatever is rubbing will wear in? It sounds and feels (through the steering wheel) like a crystal glass if you circle the rim with a moistened finger.
Does anyone know what this is? So I can assist my SA in addressing it?
Thanks for any help.
DRP
DRP
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
