5Series.net - Forums
-   -   anyone in the DMV do coding ?? (https://5series.net/forums/e60-discussion-2/anyone-dmv-do-coding-120444/)
i2vicious2 Jan 17, 2012 02:23 PM
i am interested in coding a couple of things on my car is there anyone available in the dmv to do this? also is there someone that i can remote desktop with to get this done? i will order the cable.... thanks.
or_550i Jan 18, 2012 09:47 AM
There's no-one at any DMV that would code a car. The most the DMV does these days with an OBD-II cable is read the ECU VIN, mileage, and emissions controls.
If you're buying the cable (hopefully the K/DCAN USB Cable) then INPA, Ediabas, and NCS expert are not hard to find. As long as you can calmly read the instructions for setting up Ediabas the coding will be easy.
luigi524td Jan 18, 2012 12:01 PM
I believe the OP is not looking for someone in the (DMV) Department of Motor Vehicles to code his car - I think the OP's referring to geography d = Delaware, m = Maryland, v = Virginia :excl:
or_550i Jan 18, 2012 02:44 PM
Whooosh! Right over my head. Thanks.
Jeff E60 Jan 18, 2012 05:17 PM
Don't feel bad, I thought the same thing. :P
crypto Jan 18, 2012 11:12 PM
You guys are close.. DMV = D.C., Maryland, Virginia
crypto Jan 18, 2012 11:16 PM
I would be interested in this too. I know a guy on this forum that's local that has the cable and the software but neither of us have yet "experimented" with doing this yet. For my it's largely a product of not having the time to spend on trying to figure it out. That and I've been warned that if you're a noob to coding that you'd likely need a battery charger on hand to make sure you don't completely drain your battery while fiddling around given it will likely take you a lot longer than it should the first few times you start on such an endeavor.
i2vicious2 Jan 19, 2012 09:32 PM
im sure its not that hard, im willing to try, i am about to order the cable and software for it. i have a battery charger in case it dies....
i2vicious2 Jan 19, 2012 09:33 PM
sorry, i meant dmv as DISTRICT OF COLUMBIA, MARYLAND AND VIRGINIA, SORRY FOR THE CONFUSION.
or_550i Jan 20, 2012 01:24 PM
Yeah, that one went right over my head. My mistake.
If not post your questions here or on bmw coding... Here is the e60 coding list.
The most interesting will be:
LEGAL_DISCL
KOMFORTSCHLIESSUNG_FB
