Anybody know how to remove front seat back panel?
My lumbar support is really bugging me as it seems that it won't fully deflate. I want to look at the innards and maybe just put some extra cushing inside. I can't seem to remove the back panel covers though. Can anyone help?
My Ride: 2008 530d M sport
My seat is a full electric base, but does not have airbags.
Is it advisable to disconnect the battery prior to doing the seat removal as it will prevent all the seatbelt restaint / airbag errors? Anyone got any experience of doing this?
Engine: N54
I don't but i need to know how to do this as I need to get to the seat frame as the drivers seat is making a clikc noise if you lean or push it on one side, it seems like a spring has come loose or the frame is damaged so if anyone knows how to remove the seat back panel or even take out the whole seat that would be great.
Purchase some felt type materal from a fabric store or Wal-Mart. Remove the plastic cover - the same one that covers the hinge and the switches. Stuff some felt inside the plastic cover.
My SA had this done on my first 2 E60s and I did it myself on the third. No more 'clicks" and cost about $1.00 in felt.
I found out how to do it. It's not too bad if you remember that you must touch the clip on one side and bang the other. Here is a link to the instructions in case others have this problem.
http://tis.spaghetticoder.org/s/view.pl?1/07/20/29
Turns out that the lumbar is indeed fully deflating. The problem is there's a large support spring right in the lumbar area that is just too tight on mine. It has no give and pokes me in the back even when the lumbar is fully deflated. I thought about cutting it but decided to just pull it back with tie wraps. Much better for me now.
I know the exact problem. I have fixed in on three different E60s and you don't need to remove the seat back. The noise is actually coming from the plastic cover area on the side near the hinge and "clicks" when you turn, stop-go, etc.
Hi,
My problem is not the lower part of the seta but the upper part which would effectively be behind your left shoulder (RHD driver car) It makes a click if you put pressure on it and is probably a fifth of the way from the top of the seta down.
I thought it was something to do with the headrest but it doesnt seem the case. It seems to be a frame problem.
I presume the problem that you are one about is a lower seat problem that occurs near the switches and the hinge. Mine is actually on the main part near the top and headrests
I have the same clicking sound in the back part of my driver's seat. It's minor and I have not mentioned it to my SA but any insight or recommended fix would be greatly appreciated. Thanks.
kane1111
04-10-2015 04:40 PM
