Any DIY sources for this repair?
Hi I have an e60 2007 525i and I was told by a reputable mechanic that I need to change the lower radiator hose ( Part # 17127521778) the temp sensor ( Part # 13621433077) and a 4 way hose that seems to be known as the return hose as well (Part # 17127560160). They want $1300 to do it but I can get the parts for no more than $300 so I'm trying to find any resources that shows a DIY of this procedure to gauge if it's something I'm capable of doing. The 4 way hose is giving me the most trouble as far as finding info online. I've done repairs on the car before but they all had ton of DIY resources I was able to watch and read before performing. Any help would be appreciated. Thanks.
Worth noting: I was told there was a coolant leak on the temp sensor of the lower radiator hose and that the 4 way hose looked swollen from a previous oil leak. This is why the need for replacements. |
Sounds like those are just recommendations. Is your car not running properly?
Originally Posted by donpb
(Post 1613549)
I had that too. Mine cracked when the water pump failed. Do the reservoir and if it's not that, then move on to the next suspect.
Originally Posted by memphis1212
(Post 1613548)
Thanks so much for the help guys! Will post back with results.
