any coders out there? 545 coding to add aux in, need help
Old Jun 10, 2014 | 02:46 PM
eazye757's Avatar
My Ride: 545i
Default any coders out there? 545 coding to add aux in, need help
all.
after completing my coolant pipe a few weeks back I became motivated to tackle other tasks such as adding the aux pipe to my 545. I have physically installed the cord under my radio. got all the way to the last step of coding ( according to this video on youtube BMW E60 5 series How to code AUX in Idrive ncs expert step by step - YouTube ) and when I went to code the ecu I'm getting the error code as seen in the attached pic.
any ideas gurus? I've been on bmwcoding.com but not to much help there.
Attached Thumbnails any coders out there? 545 coding to add  aux in, need help-screen-shot-2014-06-10-6.08.14-pm.jpg
Old Jun 10, 2014 | 02:49 PM
eazye757's Avatar
My Ride: 545i
after uploading pic i see its not really legible. here is what the error says
Fehler in cabd siehe cabi.err und error.long!
coapi-2060 coding faulty general
mask60 c_c_auftrag: error ecu incorrect response id
Old Jun 10, 2014 | 02:54 PM
txag_530i's Avatar
I believe that the software is trying to "ping" the M-ASK module and is unable to do so. You might have to upgrade the DATEN files in order to get the correct file that matches the installed module.
Old Jun 10, 2014 | 02:59 PM
eazye757's Avatar
My Ride: 545i
this is my first coding job so I'm a noobie. can you tell me step by step how to do that?
Old Jun 10, 2014 | 08:27 PM
e60rider's Avatar
My Ride: 2008 528xi (Silver)
Had the same problem when i first started coding. The software you download (and i did the same) has old DATEN. After updating daten youll be able to code.
Old Jun 11, 2014 | 07:01 AM
eazye757's Avatar
My Ride: 545i
How do yo update the DATEN? I was doing some reading and it looks like you update the files in ncs expert but where to do you get the updated files from?
how did you fix yours?
Old Jun 11, 2014 | 11:57 AM
txag_530i's Avatar
Keep reading at BMWCODING.com
Old Jun 11, 2014 | 12:56 PM
DR545's Avatar
My Ride: E60 545i
Before going through the trouble of updating your DATEN, are you sure you setup your cable correctly? The most important thing is once you plug in your USB, is it connected as Port 1? I had the same issue or an issue (not sure if it was coapi-2060) and it turned out that the Port was set to another number. Make sure your settings are set correctly under Port setting:
Bits/sec: 9600
Date bits: 8
COM Port number: 1
USB Transfer Sizes: 4096
Latency Timer: 1
Timeouts: 0
If it is then go ahead with the DATEN update. FYI you should look into updating your DATEN anyways.
Old Jun 11, 2014 | 06:27 PM
e60rider's Avatar
Yes ^ , you should check via INPA that your connection is good. Also I just found it from a thread on BMWCODING. If you need me to send them, id be more than willing to. But i believe you will only need the e60 updated DATEN, but if you have more models you'd like to get coded. You will need to update all your DATEN (around 4gb).
Old Jun 12, 2014 | 02:54 PM
eazye757's Avatar
My Ride: 545i
Default Finally got it!!
Finally got it to work this evening. didn't change any settings, just tried it again and the next thing I knew the idrive went out for a few seconds and upon return AUX was visible!! I wish i woulda tried this years ago lol. Thanks everyone for the input!!!
