Antitheft switch
Where is antitheft switch in BMW 528i 2008.
I know it's under the hood somewhere...
Is it safe to switch IT off when the hood is open for a long period of time ?
And how do u switch it off ?
For e.g when u hv battery tender connected for about 4 weeks, then hood will be open ....
If I have a few free minutes tomorrow I'll snap a pic of the tender and how I connect it to my Roadster battery (because I only drive that car when the weather is PERFECT)! I'm sure you'll be able to figure it out from that. However if you're really not comfortable doing these sort of things you should rely on a BMW service center or a qualified independent BMW mechanic to assist you.
The cord compresses in the trunk gasket so I can close it completely without any difficulty.
Hope this helps you!
My Ride: 07 530i Mystic Blue
Sure ... here ya go - this is as connected to the battery in the trunk of my roadster. A battery tender is helpful as this car is driven only when I feel like it and the weather is perfect. The leads are attached to the appropriate + / - battery terminals and the plug makes it very easy to connect and disconnect safely reducing the possibility of any shorts.
Thanks for the pix. Quick question when you get a chance.
When you replaced you battery, I see that you have Interstate, did you have to get it registered in your car? I read that it's required? Please advise. My car is at 49k and running on my first one (3.5years old) and considering getting a new one.
Thank you sir.
Thank you sir.
Thank you sir.
The picture is the battery and tender installed in my Roadster; battery registration isn't required in that car. If you replace your current battery in an e60 it is recommended that it be registered. That said, if your battery is the original and you drive enough every day to maintain it in a good charged state ... or when not driven use a battery tender ... your battery could last 5+ years. I wouldn't replace it as a maintenance item unless you are getting symptoms that it is failing.
