5Series.net - Forums
-   -   Anti-trap rear window close then reopen (https://5series.net/forums/e60-discussion-2/anti-trap-rear-window-close-then-reopen-99343/)
SmG-Deuce May 30, 2010 12:08 PM
My rear driver side window close then pops back open. Anti-Trap message came on the idrive but went away. Anybody knows of a solution?
Anzafin May 30, 2010 12:50 PM
I guess resetting the anti-trap function will fix it.
Check the owner's manual for instructions :thumbsup:.
- Antti -
bimmer722 May 30, 2010 12:57 PM
This is off the top of my head but with the window rolled up you press down on the button to open the window and without letting go keep pressing down for 20 sec. Then pull up and let the window close all the way up before releasing the button. That should do it.
SmG-Deuce May 30, 2010 01:35 PM
Thanks for the help
Gene May 30, 2010 03:03 PM
https://5series.net/forums/topic/258...9&#entry618509
problemchild1one Jun 3, 2010 09:25 PM
tried that for 20sec and sign came up on the screen saying power window anti trap function and now it doesn't wanna roll down...please help
KMonster Jun 8, 2010 08:41 PM
I had a similar problem where both the driver and front passenger windows would go up, close, then go back down. This would especially happen on warm days. I tried the resetting method to no avail. While the car was still under warranty I took it in to get fixed while getting the oil changed. Of course it didn't happen at that time. When I go to pick up the car it happens. Dealer changed motors on both windows and I never have had a problem since.
KM
problemchild1one Jun 8, 2010 09:23 PM
damnn so that means im probably gonna have to change the motor??? i hope not and it doesn't happen all the time! idk what to do please help
Jon M5 Jun 9, 2010 06:14 AM
I have had this fault on my M5 a few times. It's been very intermittent though, and I just live with it! Really isn't that big a deal for me to get worried about as it only happens once in a while. I certainly wouldn't go and buy new motors to fix it! However, that's just me! If your fault is happening more often that once every so often, and is more persistent, then I'd go and try your luck at the stealers and trying to get BMW to pay for the motor's out of goodwill, or warranty if you still have one or have extended it etc.
