Anti Trap Deactivated
Old Oct 20, 2005 | 04:39 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Hi,
2 days ago, I got this message "Anti trap deactivated" and then my driver side front window would not go up automatically. I seldom roll down the windows. How did this happen ?? Another computer glitch ??
Any comment is apprecaited.
Old Oct 20, 2005 | 06:34 AM
525iSE's Avatar
Originally Posted by lcc014' date='Oct 20 2005, 07:39 PM
Hi,
2 days ago, I got this message "Anti trap deactivated" and then my driver side front window would not go up automatically.? I seldom roll down the windows.? How did this happen ??? Another computer glitch ??
[snapback]186501[/snapback]
I had that same problem after i tinted my windows... but after i roll all my windows down then back up... the message was gone... yours still showing or is it gone now?
Old Oct 20, 2005 | 06:48 AM
colejl's Avatar
Originally Posted by lcc014' date='Oct 20 2005, 12:39 PM
Hi,
Occasionally does that... It's a design feature!
I think they're a bit sensitive to protect your fingers etc...
Old Oct 20, 2005 | 07:18 AM
swajames's Avatar
I've also seen that this could be a software bug. What version are you running? My SA said that there were issues with older S/W versions so an update might help here?
Old Oct 20, 2005 | 07:20 AM
stream's Avatar
Banned
Fairly common problem. Do a search--there's a way to reinitiailize the affected window--try that before going to dealer.
Old Oct 20, 2005 | 08:03 AM
billysunshine's Avatar
Had the same problem, dealer said it was the software. They had the car for a day and fixed it with an update.
Old Oct 20, 2005 | 10:59 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
I haven't had any software upgrade since day 1. So it could be an old software bug.
I will try to lower all windows and see what will happen ...
Thanks,
Old Oct 24, 2005 | 01:31 PM
IndianGoneMAD's Avatar
My Ride: '06 530i, Titanium Silver, Gray Leather, Sports PKG, Premium PKG, Sound PKG, Cold PKG, STEP Tranny, Power sun shades, fold rear seats, rear seat heating, PDC, Nav
Mine had the same "error" when I picked it up from the dealer last week.
Both, rear windows had the problem.
How I "fixed":
Go to each door that is in "error":
Lower the window (mine was stopping after about 3"), continue to hit the button, until the window is completely lowered and hold down the button for 5 secs.
Raise the window (mine, again, was stopping after about 3"), continue to raise the window, until the window is completely raised and hold the button for about 5-10 secs.
Repeat for each door....then "error" has been gone ever since....
Old Oct 24, 2005 | 06:30 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Just picked up my car from dealer for oil change, anti-trap deactivated, sunroof making cracking sound when closed from tilt position, and tons of I-Drive issues. Dealer also replaced the wiper blades for me. They upgraded the software and now, radio is off if I turned it off before shutting down the car. I need to reconnect my blue tooth phone. Dealer didn't say the software version number on the invoice. Dealer reinitializied the windows to get rid of the anti-trap message. Sunroof sound issue was due to loose clips.
Old Oct 24, 2005 | 06:51 PM
EBMCS03's Avatar
Try reinitalizing your windows... not sure if it will fix it but worth a try.
I believe this is the process... can anyone confirm?
Roll them all the way down then roll them all the way up by HOLDING the switch (*not by auto up*) and then continue to hold it up for 3 extra seconds... that should reinitalize it.
