5Series.net - Forums
-   -   Another PDC problem (https://5series.net/forums/e60-discussion-2/another-pdc-problem-135670/)
hammy2k Oct 28, 2013 04:41 PM
Another PDC problem
Hi guys got a problem with PDC the light flashes and shows on the screen but no sensors are working
I listened to all the sensors and found one that had a very faint ticking noise so I replaced it and all seem to be
ticking ok but still getting the error I checked all the connections and made sure there was noting blocking any of the sensors ,
I also tried another PDC module just to be safe and that's not the problem either
anything else worth checking before taking it to my local bmw garage and spending a lot of money ?
edit: they started to work a couple of times tonight but then threw up the PDC error and stopped working again
hammy2k Oct 31, 2013 02:21 AM
bump
Jim165 Oct 31, 2013 05:05 AM
I'm having the same issue...PDC works fine for one day and goes haywire the next. It seems that if one sensor fails, the whole system crashes. Everytime i check them they seem to be working okay, so I don't know what to do. Giving you a bump for anyone else to chime in...
