annoying noise !!
My Ride: 04 545i 6 speed
92 535i 5 speed
88 325i auto
my car makes annoying clunk noise when i press the clutch to shift from 1st to 2nd or 1st to neutral at low RPM, also its makes clunk
when i turning the engine off
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
based on my research on this topic, it is "normal" according to BMW. I get the same sound going from 1st to 2nd gear. If i release super gently, I will avoid it. It also does this "click" in reverse. I hate it. Has to do with the Dual Mass Flywheel or something like that.
My Ride: 2013 550i M Sport 6MT Alpine White, 2013 X5 50i M Sport Alpine White
I'm new to my 6MT 535.... I got it because of the fun factor and also because my last 550 AT had tons of problems... do you find that the manual/clutch is virtually trouble free? I had 5 Japanese manuals before (which I drove hard), and the clutches all lasted 100k miles...
Let me know if there's anything I should expect with the BMW manuals early on. thanks!
I've recently noticed this as well. I refuse to believe it is 'normal'. I popped the hood and gave the engine some load in a parking lot to see if it had a lot of movement, but it looked OK. I guess that ruled out the engine mounts. Maybe something trans mount related?
