Angel HeadLights
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
Originally Posted by price9195' date='Nov 19 2004, 01:16 AM
post hijack...you serious about the M5 realty man? If it were out by now I would have given serious consideration but not sure I was high enough up on my dealers priority list.? I've only bought one other car from this dealer.? Although he said a $100 deposit is all it takes to reserve a spot for any of BMW's "specialty vehicles"
[snapback]57975[/snapback]
Many things can happen in that amount of time, but I'll say that it is in the running.
Originally Posted by Your BI-Xenon light' date='Nov 18 2004, 11:19 PM
[quote name='EBMCS03' date='Nov 18 2004, 11:24 PM']Both high beam and low beams are Xenons right?
[snapback]57950[/snapback]
You face FOUR "main" lights at your car:
The inner lights are HALOGEN, the outer are XENON.
BI-Xenon does mean that the outer lights are used for LOW beam and HIGH beam function as well. Their different positions are switched mechanically in the center of the concave mirror. You can hear that standing in front of the car when a friend will switch on /off HIGH beam (Engine should be off).
It does NOT mean, that the inner lights are XENON. That always means, the bright light is always generated by the outer XENON (high ignition bulbs), not by the inner.
The inner lights are switched on for HIGH beam and FLASH beam as well, nevertheless this is more or less a design feature and not comparable to XENON ....
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
The inner Halogen bulbs in any case are always used for the FLASH signal (trying to beam off the car in front of you ...) Driving at night you will recognize, that HIGH beam is much brighter than FLASH beam (XENON HIGH beam beams a half circle in front of you).
In the darknes it is much more effcient to "flash signal" the car going ahead with HIGH beam than with FLASH beam, although it is forbidden (in Germany)
Regards
Jack-E61
[snapback]57978[/snapback]
[/quote]GOOD anyone that cuts me off can stare into my Xenon HIGH BEAMS
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Maybe it's a US setting, but mine works different.
If I use the flash signal (pulling lever towards me, only the inner holgens come on, just as mentioned.
When I use high beam, pushing the lever away, both the high beam xenons AND the inner halogens come on. Truly a sea of light.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
