5Series.net - Forums
-   -   Always starts on radio, not CD (https://5series.net/forums/e60-discussion-2/always-starts-radio-not-cd-151793/)
McPikie Jul 6, 2021 01:34 PM
I have a 2006, think its professional as iy has widescreen. If I am listening to the CD changer when I shut the car off, when I start it back up again, its switched to radio. Is there a way to set to stay on CD?
donpb Jul 6, 2021 05:46 PM
Has it always been like that?
McPikie Jul 7, 2021 02:06 AM
I've only recently bought the car
donpb Jul 7, 2021 02:21 AM
Has it always been like that since you've owned it?
McPikie Jul 7, 2021 06:35 AM
Yes. I've only driven it 3 times though
donpb Jul 7, 2021 11:21 AM
You may just need a software update. I'd have an indy BMW specialist diagnose it just to be sure.
seanjordan20 Jul 7, 2021 06:38 PM
I would program the driver settings to see if that works first. Set everything up the way you want it then go through the memory save procedure. That's utilizing the M1/2 buttons on the side of the driver seat. If it doesn't work you can code it in but that process is probably out of your scope.
McPikie Jul 12, 2021 03:17 AM
I only have half electric.
Using it at weekend, it was sporadic. Sometimes it started back on CD, other times on the radio.
seanjordan20 Jul 12, 2021 08:12 AM
Do you have what's needed to code. I can tell you the steps
