Alternator Failed after Alternator Bracket Oil Leak Repaired
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
The bearings are on of the most important. Do you know why yours failed. Are you sure yours is a Valero instead of a Bosch. Check to make sure. If you want to figure out how to reman one and have $60 to play with you should try it. The first one is always the hardest. You tube has a few how to videos.
