alignment yes or no?
Old Feb 17, 2009 | 09:44 PM
550i now's Avatar
My Ride: 2011 550i; Alpine White/Black Dakota/MSport/SAT/IAS/Driver Assistance/ConveniencePkg/Prem Pkg 2/4 Zone AC/Side-Top Cameras/HUD & Black panel/BMW Apps-iPhone 4 Media/M Decklid spolier /Ventureshiled clear bra/ V1 -Ordered 4/9/11, Production 4/19, Shipped on Martorell 4/23,Arrived Port Hueneme 5/19,Delivered 5/21/11
My 2008 550i has 13K miles and over last 2K miles have had pulsating /hum from front left wheel area at speeds between 40-55mph on non grooved pavement. Tires look OK, modest wear, but no significant cupping on inner edges.
Took her in for first regular service today, asked SA to check out.
He came back recommending alignment, $249 since I have active steering.
alignment as far as straight tracking is perfect, steering wheel straight dead on. I have no alignment concerns.
So...the $249 question? Will a fresh alignment alleviate the pulsating hum, likely not I think, or it will come back within a few thousand miles as the tires wear further.
What do you all think?
Old Feb 17, 2009 | 10:48 PM
zagato's Avatar
I don't think you need an alignment, you might have a rim "bent".... if your car drives straight and does not "pull" left/right the alignment is not the way to go.
Old Feb 18, 2009 | 12:23 AM
artfromspain2004's Avatar
My Ride: E60 monacoblau metallic, steptronic, leatherette beige, xenon, business.
Well the same doubt came to me when I replaced the 4 tires 1 year ago. They told me to make it past 3 o 4 months but I have not still made it. Now, I don't know if it worths.
Old Feb 18, 2009 | 12:24 AM
v_therussian's Avatar
I'd check the trim, just like zagato suggested. And also, though this may not be the case with e60, but I had a similar situation on my A6 and it turned out to be suspension linkage. So definitely look into all possible causes, as the $249 alignment may not even be the solution for this at all...
GL keep us posted
Old Feb 18, 2009 | 12:29 AM
mini_me's Avatar
Can't you swap rims with somebody for a day? This would confirm/rule out the rims/tyres.
slow.motoren.werke
DIY: Do It Yourself
Aug 25, 2015 03:46 PM
maxcbrdriver
Aug 20, 2015 10:40 AM
PelicanParts.com
Aug 10, 2015 01:55 PM
Grrrit
Aug 3, 2015 04:16 AM
Teddy1993
DIY: Do It Yourself
Jul 23, 2015 07:54 PM
