Alignment issues or new rear tires?
Old Dec 28, 2012 | 04:07 PM
jgbmw's Avatar
Default Alignment issues or new rear tires?
I got an alignment and 2 new tires for the rear. Now it seems the steering pulls slightly in either direction depending on irregularities with the road surface. The steering tracks straight on level surfaces.
Is this the alignment or the new tires causing the issue?
Also, the technician stated that he adjusted the negative camber slightly to improve inner tire wear for the rear tires. However, the alignment is in spec.
Old Dec 30, 2012 | 10:46 PM
SoCal530's Avatar
I would imagine since you have no problems on even roads but have issues on uneven roads, that your problems lies with being on uneven roads.
Old Dec 31, 2012 | 02:43 AM
tonyb635's Avatar
When I put my new tires on a while back I had a similar issue. Alignment was ok and I noticed it a lot more on roads with wear. I assumed it was due to the new tread gripping better than the old, but I'm not sure.
chadillac2000
42
Sep 13, 2017 11:15 AM
blackstarr
Feb 13, 2016 08:34 AM
kongse
Jul 17, 2015 03:29 PM
rteone
Apr 7, 2015 11:48 AM
Jun 17, 2003 09:38 PM
