Alignment after Coilover Install
My Ride: 550i SMG, HUD, Cold Weather/Sport Package, Mtech front bumper, Oem M5 rear bumper, V1 Concealed, RPI Scoop, 6000K HID both Fog and Headlight, M5 mirrors, LED interior lighting, M5 SMG Shift Knob, Eisenmann Sport Exhaust Quad Pipe, 30% Tint, Sprint B
I just completed installation of KWv2 coil-overs, tension struts, and control arms. (Note: Strut Bearings were replaced) I drove the car for a couple miles after the install and waited two weeks for the suspension to settle before having the alignment done. After having the alignment completed I have noticed some vibration feedback from steering wheel (not speed sensitive). I have also noticed at lower speeds a slight left and right rocking motion of the steering. I have had a mechanic look over the suspension to see if there was anything loose or if the tie-rods were bad but did not find anything wrong. I also swapped my wheels with a set of stock wheels to see if the wheels and tires were the issue but still experience the same issues. I have posted below my alignment settings. Note I just noticed my front camber settings were the same after alignment. Could these camber settings be the source of the issue? Is there anything else that could cause this issue.
socale39
09-05-2023 08:30 AM
chadillac2000
07-01-2015 05:58 AM
TexaZ3
05-06-2015 09:54 AM
