Alarm goes off for no reason
Yes. Some websites have a mod point based system and +1 means you are up voting someone's response.
BTW, welcome to the Internet. Oh, and 5series.net
My Ride: 530i 2006 model w/ Nav
This isn't much help, Will, just a rough overview of the alarm system. Hopefully someone will chime in soon with some real knowledge.
http://www.bmw-planet.com/diagrams/r...0e61/index.htm
Antitheft Alarm System
Functional description, see BMW Technology:
TIS -> Documents> SI Technology -> 61 09 03 (031)
Notes on function
The DWA electronics are integrated on the ultrasonic signal/interior sensor control unit. They evaluate the signals relevant to the alarm
system and decide whether the alarm should be triggered. The control unit is connected to the data bus K-CAN SYSTEM, across which it receives
the signals of the door modules and CAS and body base module control units. In addition, a separate DWA data bus is connected to the control
unit, across which the signals between the DWA electronics and the control unit emergency siren/inclination sensor (SINE) are transferred.
The inclination sensor and the emergency siren are grouped as one component. They are linked to the DWA electronics across the DWA data bus.
The inclination sensor monitors the horizontal and vertical position of the vehicle and issues an alarm signal in the case of a position change.
The emergency siren emits an acoustic alarm if required. The alarm is triggered when the siren receives a corresponding command from the DWA electronics.
In addition, an alarm is triggered independently of the DWA electronics under the following conditions:
Emergency siren is disconnected from the vehicle electrical system
Disconnection of the vehicle battery
Rapid discharge of the vehicle battery
Overvoltage in the vehicle electrical system (voltage > 16 V)
So that the emergency siren can operate independently of the vehicle battery, it is given a rechargeable battery that is charged when the
engine is running.
In accordance with country-specific legislation, the emergency siren can be coded for an interval or intermittent tone.
In addition to the alarm trigger, the emergency siren can issue an acoustic acknowledgment signal on arming or disarming. This function can
be coded depending on country.
Notes on function
engine is running.
Will
My Ride: See my signature
If you just had a lot of engine work done make sure it's not the hood closing sensor. It can easily be damaged or moved. I had this happen to me a few years ago with my first E60. It's a cheap part if it needs to be replaced. If I recall it cost me about $20 to replace it myself. After that I had no more phantom alarms.
If you just had a lot of engine work done make sure it's not the hood closing sensor. It can easily be damaged or moved. I had this happen to me a few years ago with my first E60. It's a cheap part if it needs to be replaced. If I recall it cost me about $20 to replace it myself. After that I had no more phantom alarms. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Yup. its your hood sensor
Notes on function
engine is running.
Notes on function
engine is running.
You were exactly right. Battery had barely any voltage and was the original (06 model but was actually manufactured in 05). Indie explained it was a calcium battery (don't really know what that means) and that their lifespan is shorter than a normal car battery and that now that it is 2010 it was about time for a new one. I like this mechanic shop a lot... they talked me into a BMW battery. It was expensive $313......you think I got hosed? They were pretty adamant about the BMW battery and they checked for some others to work (Interstate, etc...) but there was not one comparable.
Thanks again,
Will
Vman33
03-14-2022 04:43 AM
