2 Attachment(s)
I was fixing the door trim (something was not fastened properly inside) and tested the locking mechanism with the key in the ignition, when done and everything was back in place, I started the car. And there it is- an airbag warning. I must have forgotten to plug the side airbag module when I tested the locking system.
Does anyone know if this can be reset without going to the dealer? If not possible, how much will the dealer charge? Attachment 107150 Attachment 107151 Thanks in advance. |
Originally Posted by Rizbel
(Post 1188163)
:dance: Found a good indy shop that specializes in airbag repair. They were able to fix the warning message with a Snap-On machine with a special key. :twoup: First attempt with a mobile airbag service was a no-go :thumbsdown:, didn't have the right tools.
