airbag problem.
Old Jul 3, 2023 | 07:00 PM
  #21
bmw1982's Avatar
My Ride: 525xi
Do you have the battery unplugged while messing with the sensor? If you check ohm it should be 2-2.5 ohms
no i did not have battery unplugged.it is 9pm i will do it tomorrow with battery unplugged and other sensor
Old Jul 3, 2023 | 08:21 PM
  #22
donpb's Avatar
My Ride: '06 530i N52
The code is not clearing because you have not fixed the problem. First, check the resistance at the sensor, then check it at the module.
No need to disconnect the battery if you disconnect the module. You will need a wiring diagram.
Old Jul 5, 2023 | 01:16 PM
  #23
bmw1982's Avatar
My Ride: 525xi
I got new sensor in few days will try to install that one. When I was checking resistance, I had a car on so I will wait for new sensor disconnect module and test ohms on connector and new sensor install everything back and see if it fixes.it say 93c9 code there is nothing else fault wise but sensor or broken wire to sensor.
Old Jul 5, 2023 | 07:15 PM
  #24
donpb's Avatar
You are on the right track.
Old Jul 8, 2023 | 01:41 PM
  #25
bmw1982's Avatar
My Ride: 525xi
Is air bag module located under the seat and how do you reset module after colision
Teekay1983
Mar 1, 2015 01:40 PM
AchtungE60
DIY: Do It Yourself
14
Dec 27, 2013 01:14 PM
rene525d
Sep 9, 2010 03:16 PM
klr44
Aug 28, 2009 02:52 PM
SMG353
Nov 7, 2007 08:06 PM
