5Series.net - Forums
-   -   airbag problem. (https://5series.net/forums/e60-discussion-2/airbag-problem-153319/)
bmw1982 Jul 1, 2023 06:09 PM
airbag problem.
I have 525xi 2006 with airbag icon and seat belt icon and code indicates front impact sensor problem replaced it but I cannot clear the code. I would try to calibrate the passenger seat, but it says connect the seat to car cigate plug in and calibrate what is that?
donpb Jul 1, 2023 06:53 PM
Please post the existing code(s).
bmw1982 Jul 1, 2023 07:28 PM
93c9
donpb Jul 2, 2023 04:31 PM
Barring the new sensor is not faulty, you could have a poor connection or faulty wiring.
bmw1982 Jul 2, 2023 04:34 PM
so I can just use multimeter and check connector with it
donpb Jul 2, 2023 05:05 PM
Yes, both ends.
bmw1982 Jul 2, 2023 05:10 PM
Originally Posted by donpb (Post 1618634)
Yes, both ends.
cool thanks I will post later how.it goes
bmw1982 Jul 3, 2023 11:24 AM
I tested the end connector no power which fuse is for front end impact sensor or is there one fuse for both front impact sensors
seanjordan20 Jul 3, 2023 11:48 AM
I would take a look at the wiring/connector. I believe the sensors are managed by the SRS control module by resistance not power. Did you use a new sensor or used sensor? Did you clean the connector pins?
seanjordan20 Jul 3, 2023 04:07 PM
Also I'm not understanding why are you trying to calibrate the seat map when you don't have an error for it? It shouldn't need calibration if you replaced it.
