airbag problem.
Old Jul 1, 2023 | 06:09 PM
bmw1982's Avatar
My Ride: 525xi
Default airbag problem.
I have 525xi 2006 with airbag icon and seat belt icon and code indicates front impact sensor problem replaced it but I cannot clear the code. I would try to calibrate the passenger seat, but it says connect the seat to car cigate plug in and calibrate what is that?
Old Jul 1, 2023 | 06:53 PM
donpb's Avatar
My Ride: '06 530i N52
Please post the existing code(s).
Old Jul 1, 2023 | 07:28 PM
bmw1982's Avatar
My Ride: 525xi
93c9
Old Jul 2, 2023 | 04:31 PM
donpb's Avatar
Barring the new sensor is not faulty, you could have a poor connection or faulty wiring.
Old Jul 2, 2023 | 04:34 PM
bmw1982's Avatar
My Ride: 525xi
so I can just use multimeter and check connector with it
Old Jul 2, 2023 | 05:05 PM
donpb's Avatar
Yes, both ends.
Old Jul 2, 2023 | 05:10 PM
bmw1982's Avatar
My Ride: 525xi
Yes, both ends.
cool thanks I will post later how.it goes
Old Jul 3, 2023 | 11:24 AM
bmw1982's Avatar
My Ride: 525xi
I tested the end connector no power which fuse is for front end impact sensor or is there one fuse for both front impact sensors
Old Jul 3, 2023 | 11:48 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I would take a look at the wiring/connector. I believe the sensors are managed by the SRS control module by resistance not power. Did you use a new sensor or used sensor? Did you clean the connector pins?
Old Jul 3, 2023 | 04:07 PM
Also I'm not understanding why are you trying to calibrate the seat map when you don't have an error for it? It shouldn't need calibration if you replaced it.
