Airbag Fault Sensor ON!!!
arrghgh...just cleaning up my car this morning..and suddenly the airbag fault warning just went on...
anyone encounter this problem? Is there anything i can do without going to the dealer and have my car reset-ed?
Location: US (Bay Area/So Cal) and Europe (UK + Germany)
Dealer needs to do this.. Just play "dumb" when you go in... You didn't go nuts on the cleaning (e.g. door panels off or anything??)
i got the same problem, it says passengers side air bag something faulty.....
also my cup holder is broken and my door seals make a really annoying rubbing sound. has anybody else had these problems. i still have to take it to the dealers for a check up.
I didnt go nuts on cleaning. I just vacuum the car and the sensor goes on. I think it is a software glitch. . will be scheduling for a check soon.
the driver's side airbag fault signal lit up a few weeks ago on mine. I have just ignored it since I figure its a stupid computer glitch. Guess I will have my dealer check it out when I take her in for an oil change which shouldnt be too long now.
Also happened on mine. Anyone knows how to look under the front sport seats, to check if my daughter did not disconnected some connectors there? Should the seats be removed or how can I look there? If I sit on the back seats, I cannot bend the neck that much...
