Air Conditioning/Ambient temperature problem
Hello all-
I've been reading a good amount of air conditioning problems but none seem to be specific to my situation (sorry if i've failed and am repeating a question). My 2004 E60 530i's air-conditioning works GREAT when the temperature gauge is over 20*F. The problem is, when i leave my car in the Bakersfield, CA heat, the ambient temperature gauge trips out when i start the car and reads something like -40*F (yes, 40 below). When ambient temperature is below 20*F, the car will only blow hot air out of the air vents, which is moderately (sarcasm) annoying when it is actually 106 outside. Sometimes it takes a good 5 miles before it finally starts to kick on again. I've taken it to European-specific auto shops, BMW dealer, the whole lot, and nobody has been able to fix it. Does anyone have experience with this problem? Is there a way I can bypass the temperature sensor? My hypothesis is that the sensor sitting in the car gets too hot and resets itself, but I really have no idea. Thank you for your time! |
I assume you're referring to the outside temp in the dash? Have you tried replacing the ambient temp sensor, it's in the front bumper, to the side of the intercooler, looks like an antenna
try getting codes read too |
Originally Posted by thenameisnick
(Post 1547494)
Hello all-
My ambient sensor also reads -40 but thats how i bought the car, it was involved in an accident so i just see a bunch of wires hanging below my headlight. My ac currently has that same problem but here's whats weird, ive had it like that for about a year and my a/c has worked fine up untill now, so hopefully its an easy fix for you brother.
Originally Posted by docsilva
(Post 1547526)
easy job, took me 10 min,,, good luck |
Hey thanks brother ill give it a look.
Does anyone have the part number for the Ambient temp sensor?
Try realoem.com
