AGM Battery for E60
My Ride: 535
Model Year: 2010
Here is my research on AGM Battery Replacement. All the below are workable and have the exact specifications and could be all made in the same factory. The Home Depot one is the exact brand too. The Pep Boys & advanced Auto one looks really good price.
Original BMW AGM Battery - Made by Exide
850CCA, 160RC, 92Ah, 850A
13.5 x 7.5 x 7 inches
S: 61217639054
AW: 61217639053
165902-10 US
https://www.pepboys.com/product/deta...0763_affiliate
Part #: 49-850BAGM| SKU: 838838
Discount: 25%
Discount Code: ROADTRIP25
Save 25% with code PEP25BATT
$180 after 25% discount
http://www.homedepot.com/p/Edge-L5-4...49DS/205342457
Dimensions
Product Depth (in.)* 6.88*
Product Width (in.)*13.88*
Product Height (in.)*7.5*
$245 no discount
http://www.autozone.com/batteries-st...?checkfit=true
Battery Height: 190 mm - 7 1/2 in
Battery Length:353 mm - 13 15/16 in
Battery Width: 175 mm - 6 15/16 in
$184 no discount
http://shop.advanceautoparts.com/p/a...000#fragment-2
Same as Carquest - Need to Open an account
Discount: 30% / Up to $50.00. Discount Code: TRT30
Cold Cranking Amps: 850. Cranking Amps: 1000. Reserve Capacity: 160
Height: 7.5. Length: 13.94. Width: 6.938
$186 then get a 30% discount
https://www.walmart.com/ip/Platinum-...40647529#about
Walmart Battery not yet available.
Cold Crank Amp: 900CCA H8 AGM
Product Dimensions (L x W x H): 14.31 x 6.88 x 7.50 Inches
$140
Hope this helps someone!!
S: 61217639054
AW: 61217639053
165902-10 US
Discount: 25%
Dimensions
$245 no discount
$184 no discount
$140
My Ride: 535XI
Engine: N54
S: 61217639054
AW: 61217639053
165902-10 US
Discount: 25%
Edge L5/49/H8 Auto AGM Battery-FP-AGML5/49DS - The Home Depot
Dimensions
$245 no discount
Duralast Platinum Battery H8-AGM- Read7Reviews onDuralast Platinum #H8-AGM
$184 no discount
AutoCraft Platinum AGM Battery, Group Size H8, 900 CCA H8-AGM: Advance Auto Parts
$140
S: 61217639054
AW: 61217639053
165902-10 US
Discount: 25%
Dimensions
$245 no discount
$184 no discount
$140
My Ride: 535
Model Year: 2010
My Ride: 535
Model Year: 2010
S: 61217639054
AW: 61217639053
165902-10 US
Discount: 25%
Dimensions
$245 no discount
$184 no discount
$140
S: 61217639054
AW: 61217639053
165902-10 US
Discount: 25%
Dimensions
$245 no discount
$184 no discount
$140
https://www.batteriesplus.com/productdetails/sli49agm
Capacity 20hr: 92AH
Cranking Amps: 975
Warranty: 48 Month Free Replacement
Weight: 57.75 lbs
Length: 13.9375 in Width: 6.875 in Height: 7.5 in
$220. 10% Discount available
Sears.com
Item Weight (lbs.):58.5
Length (in.):14 Height (in.):7.5
Group Size: 49
$150.44. look for discounts
