Aggressive style with Spacers Xi
the silver car has Miro 111's , unfortunately they do not have an offset for Xi's in 20 inch.
you will only be able to fit 19's. wheels for Xi's are i bit more complicated to get since you will also have to worry about
tire size , rolling diameter bcuz of the diff. not to mention there are not many options available
My Ride: 2007 525Xi black sapphire Metallic
spacer width should be based on your offset, i would recomend the following before purchasing spacers, once you have your wheels mounted , borrow or purchase a micrometer and from there you can figure out how many milimeters you will need. i personally have a 10mm spacer and my car is now rubbing in the back.
although i have 19x10 in the rear. please refer to the following thread which contains quite a bit of info from Xi owners such as V, myself etc
https://5series.net/forums/topic/951...nsions-for-xi/
also, member JeRZee XiE60 is selling his 20 inch wheels off his Xi for a good price.
seven11
01-23-2017 08:32 PM
