After market wheels and spacers
THe '08 550i I purchased has aftermarket Forgestar f14 wheels. Sizes are:
Front: 19x9 with 20 offset
Rear: 19x10 with 20 offset
Stock Tire size
For the fronts the OEM 172's are 18 offset but 8.5" wide. Anyone know if I could go 5-10mm in spacer size on the front?
For the rears the OEM 172's are 32 but 9.5" wide. Can I go 5mm or higher on the rear.
I am not sure if the extra 1/2" makes a difference or if it is the offset you have to worry about only. tks
Stock Tire size
