after market air filter.. yes or no
Old 09-18-2014, 03:21 AM
star69me's Avatar
My Ride: BMW 550I BLK
Engine: N62
Default after market air filter.. yes or no
I was at a bmw indy shop in Jacksonville fl and I asked about the after market air filters and they told me not to use them because the oil on the filter gets sucked in engine and messes up the MTF sensor and engine. Any comments on this????
Old 09-18-2014, 05:13 AM
Boland01's Avatar
My Ride: 535xi 2010
Model Year: 2010
I actually ditched the stock air cleaner and box and put in a BMS dual cone intake. That was almost a year ago. To date no issues. I do have a K&N air filter on my son's 2009 Altima. That did in fact coat the MAF with the oil and cause issues. I just used MAF cleaner on it and it took care of the issue and it hasn't happened since. That was 80,000 miles ago.
To answer your question, yes it can. However, I think it's the exception rather than the rule.
Old 09-18-2014, 05:55 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Just replaced the BMW branded air filter and cabin air filter (aka microfilter) in my wife's X5 with Mann. They are identical.
Old 09-18-2014, 06:00 AM
tonyb635's Avatar
Mann+Hummel and Mahle are the two filter producers. However, most out of the factory have BMW label on them, but the mfg. is the two suppliers above.
I have heard that the Mann filters you can purchase as aftermarket are slightly different in regard to number of pleats etc. but still meet the requirements. I guess this allows them to produce more at a lower cost. Not sure though which one you would get at the dealership though. I purchase Mann oil filters from advance auto and they are a little cheaper than the dealer, maybe one day when I am bored i'll purchase both and compare.
Old 09-18-2014, 08:00 AM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
K&N had a period of time where they were all over oiled. Yes it caused problems. What you just needed to do is wash it and re-oil it with the proper amount of oil.
Old 09-18-2014, 09:15 AM
Jim165's Avatar
Someone posted a comparison of the filters including WIX, K&N and AC Delco and the AC Delco dry filter killed the others by a long shot in regards to filtering, longevity, and general performance. K&N looks to have allowed a large amount of dirt into the engine...
K&N Air Filter Review - Debunking the Myths (and why OEM is better)
I've used Mann since i got the car and my oil analysis showed very low levels of silica resulting in excellent filtration. Just go dry filter..you won't notice much of a difference anyway...
Old 09-18-2014, 04:41 PM
star69me's Avatar
Engine: N62
Well maybe I said it wrong. I meant after market as in those cone looking performance ones that you hear sucking air and adds more HP that replaces the entire oem air filter box
Old 09-18-2014, 05:59 PM
tonyb635's Avatar
Ah ok, you mean cold air intake, or more like a hot air intake. For the 5 it's BS and there are plenty of studies out there that show a reduction in power. I have a 535 and place a nice injen on it a few years back. All it did was hisssss like a snake and eventually started throwing reduced engine power codes. Got rid of it and have had no problems since.
Old 09-18-2014, 10:57 PM
Booyaazaa's Avatar
Unless you have a N54 engine stick with stock. You really don't get any performance gains from simply changing a filter and if you do it'll be only a few hp's. I do run aftermarket dci's but that's because I'm running high levels of boost so the engine needs to ingest large volumes of air quickly.
Old 09-18-2014, 11:54 PM
bmwmonkey's Avatar
My Ride: 535xi touring
Engine: N54
Back to back dyno results to not show any performance increase with Dual cone intake filters (N54 cars). Stick with stock.
Quick Reply: after market air filter.. yes or no
