Adjusting front camber
My Ride: ACS E60
Someone please chime in and help me with this. I've had no luck searching the internet so far. I want to be able to adjust camber in the front but it seems impossible with the tiny opening on strut tower. I heard that some people will slot the 3 holes on the tower so they can slide the coilover over a bit but that sounds kind of sketchy. I know I can buy camber plates for the front but how would I adjust them with the opening on the tower being so small? Can anyone show me an example of their setup?
My Ride: 530i
Engine: M54
strut towers on the E60 are already slotted. If you want to adjust camber, you'll have to 'punch out' the locating pin on the upper strut tower. I wouldn't modify the strut towers though, they're structural aluminum and any material you remove can potentially weaken the integrity of the strut tower.
My Ride: 2005 545
My Ride: 2008 535xi
Engine: n54
I just had this discussion at my friends shop where they did it for a 335. He said you get a certain sized hex key.. shove it all the way down and unscrew it.. then you can slide it a little bit .. that's it.
My Ride: ACS E60
I have aftermarket coilovers on my car so I dont think that would apply for me. I also wouldnt want to add much negative camber to my car if it had stock suspension. There has to be someone here who has done this. To think that not a single e60 owner has modified their strut housing or came up with some sort of way to ad aggressive negative camber to the front of their car seems odd. I know its difficult with these cars but nothing is impossible.
TexaZ3
05-06-2015 09:54 AM
