Adding a set of RCA outputs
Has anyone been able to find an "easy" way to add a set of audio outputs to the existing stock sound system? My goal is simply to add an amplifier to run a JL Audio Stealthbox. The sophistication of the factory system is incredible so I'm sure its no easy task...
![](http://media.obsessable.com/media/2009/05/30/rca-cable-300.jpg)
My Ride: 05 545/6
thanks to that audio system, it can't get any easier to install what you want.
this works like a champ
My Ride: 2006 530i mystic blue
my car goes in next thursday and friday for an audio install. replacing the 4 interior speakers with mb quarts hooked up to a rockford fosgate 75x4 amp at 4 ohms. also running 1 eclipse fujisten 10' woofer 700 watt rms to a 800x1 mono rockford amp. im infusing these with a mtx req5 sound processor and summing device. the stock wiring going into the stock amp will get cut and spliced into the new wiring supplied with the mtx req5. will balance out everything and exit with rca outputs for fronts rears and subs.run the rcas to the amps power the amps, tune done. its should definalty rumble in there. ill post pix inna week
My Ride: Navy 550I
chadillac2000
42
09-13-2017 11:15 AM
