Adding NAV to an 07 550i pre-LCI
Hi all, some of you here may know me from bimmerfest. I've been a member here for a while now but never really posted any. I'm looking to add NAV to my e60. From what I understand I have two options.
CCC - what would have come on the car. Pros would be all the features my car has will remain intact. Cons are slow speed, and it's DVD based.
CIC - what comes on the 2010 models. Pros are obvious. HDD based so it is much faster, and looks a lot better. Cons are losing some features of the car, and it's not plug-and-play.
So my questions are as follows. I know the CIC is somewhat hard to install and get working. What about the CIC? I'm also assuming the CIC is cheaper, and there may be people out there that upgraded to CIC and want to sell their CCC parts. What price range can I expect to upgrade to the CCC unit, and how tough of an install am I looking at? Also, what features will the CCC add to my car besides just NAV, if anything?
I tried using the search feature, but couldn't find much info since CCC and CIC aren't long enough to use in the search bar. Sorry if this topic/question is beating a dead horse.
My Ride: '08 535i | 6MT | BMS DCI | Cobb Stage 1
My Ride: 05 545/6
I did the CCC retrofit back in 2008. back then we didn't have access to NCSExpert and coding cables, so I had to get my dealer involved. Now with the influx of DIY cables and used CCCs hitting eBay, the costs are far less.
the hassle to retrofit either is similar, I'd go for the CIC if you can get it to work with your existing controller so you don't have to cut anything. if I was to do it again now I'd definitely go CIC. Even the relatively expensive but easy Patryk option is about a grand less than what I ended up paying for everything.
By the way... LOVE your wheels. I wanted those when I first bought my car. Would still love a set if I could find them cheap enough.
You can probably get everything for a ccc install for under 1k. It's all plug and play and with very minimal coding it will work perfect. The only thing you probably won't get to work is voice command. I did it in my 525 when I had it and it's actually a very easy retrofit.
