Adaptive system & angel light failure
Hi, Im owner of 2004 530i and install new headlight lens and the adaptive system and one of the angel light are not working the question is do I need to recode it. Any recommendation will be appreciated.
Thanks
Luis
Thanks
Luis
My Ride: Stock 04 530i
Same issue happened to me last week. Shop replaced xenon light, passenger side. Brought it back, ask that they fix it. Further troubleshooting said stepper motor issue. I asked they replace bulb again, effectively making them take it apart again, including stepper motor. Issue resolved after they put it back correctly (stepper motor).
Was everything working fine until light went out and replaced? If that is the case, you need to take it apart and put back together again. If stepper motor is not aligned properly, adaptive system will not work.
Well I change it because one of them was not working at all including xenon light and also the wires are very bad conditions, so I decided two change both lenses. Another thing I change the original angel lights for anothers white bulbs the left side work fow few days but not more I put back the original bulb but doesnt work.
TexaZ3
05-06-2015 09:54 AM
rizwan1377
04-05-2015 05:22 PM
