Adaptive Headlights
My Ride: 545i
Engine: N62
Hello All:
My 2004 545i has Adaptive headlights. I see that the lights follow the travelled path of my vehicle when set to auto. My question is, does my car have auto-levelling lights? How can I tell if I do. My friends car (530i) auto levels the Xenons when he turns his lights on. I can't say I ever saw this in my car. Maybe I wasn't paying attention? I have Bi-Xenons and the lights do move side to side, should they auto level or is this another option?
Thank You,
Mike
Thank You,
Mike
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
They should also shift from down to up position when you first start your car.
EXTERIOR:
LIGHTING:
PERFORMANCE:
Yup.
Make sure you have an object in front of your car (wall, car, etc.) at night turn the lights on and the lights will move from down position to up position then back down halfway (auto leveling).
At least this is what my car does.
Not necessarily. It can be in any mode as long as you just turn on the light. I have it on auto mode and at night when I get in the car for the first time and the lights come on it auto levels.
My Ride: 2008 BMW 550i Sport
Carbon Black Metallic/Cream Beige
Manny tranny and other stuff
Recently gone, but never forgotten:
2005 Ford Mustang GT (hence the name)
Torch Red/Crimson
Manny tranny and every option available for that year
2002 Chrysler 300M Special
Brilliant Black/Light Taupe/Dark Slate
Autostick and goo-gobs of neat features that I will sorely miss
OP, make sure when you do the test, you have the car in RUN mode (all accessories powered) or start the car; otherwise if you just turn on the lights, they aren't going to move.
My Ride: G30 530i M-sport
Model Year: 2018
If I recall correctly, your Xenons will auto-level regardless of whether they are in "auto" mode or not. The "auto" mode triggers the adaptive functionality and the light-sensitive on-off operation of the lights, if you have these options.
My Ride: 2006 550i Black Sapphire/ Black leather, NAV, Sports Pkg, Active Steering, Shadow Trim, PDC, Heated Seats/Wheel, Logic 7 Sound, 6 Disc Changer, Blue Tooth, Comfort Access/Seats, ACS Aluminum Pedals, Bi-Xenon lamps and MTEC 2X Super White Foglights
On a side note, what does the headlight line portrayed out in front look like on your cars? Mine seem like they may need aligning. Both appear to have a crooked line that is lower on the left and higher on the right. Maybe lower on left, so I don't blind oncoming traffic or the car in front of me, but higher to the right (this may be reversed for Euro cars). At a minimum it seems like the crooked lines should be sync'd up.
TIA
