Adaptive headlights
My Ride: 2008 BMW 535i
While parked, when I turn the steering wheel to the right, I can see the headlights turn to the right and the "DRL" turns on as well.
When I turn it to the left, the headlights don't turn but the "DRL" turns on.
Is this normal or should I take it into the dealer? My cars a CPO so this should be covered right?
My Ride: BMW E60
Model Year: 2016
That is normal. It's designed this way so you don't blind the oncoming traffic.
Also, the DRL you're referring to is actually the cornering light for LCI cars. Which can actually be disabled via coding if you want. Or changed to fog lights if I remember correctly.
Not entirely true. I've seen the adaptive light flashing which is an indication of something wrong with the system yet there was no warning on the Idrive. This happened to my sister '05 645
