Active Sway bar bushing weld broke off my 545i
I have a 04 545i with active sway bars and active steering. last week while I was driving home I noticed a clunk that got worse as I got down the road. Then I noticed a rubbing/ grinding sound when I turn to the right at speed. No rubbing/ grinding sound at very low speeds while turning right. No rubbing / grinding while turning left at speed and at slow speeds just clunking.
Got home jacked the car off and started to shake things . Got to the sway bar and saw the whole driver side bracket broken off at the bottom weld. Wtf!!! How does that happen. Called BMW North America and they said there is no recall but they have heard of this issue. Talked to an Indy and they advised they have seen this and sent the car to someone who welds aluminum. The weld only lasted a few months before breaking again.
I will be dropping off the car at the dealer Friday to see if this can be recalled or fixed due to a defect or something. Any other suggestions. If they don't fix it I will not be paying over 2k for them to put in new engine cradle. I guess I'll be trying to find someone that welds.
Question is should I find someone to weld it? What's causing the grinding rubbing sound? Is it the active sway bar motor?
Thanks
Thanks
Yessir, Healthservices had this happen to him. I would send him a message, he is pretty responsive. He welded his back together himself, but he's got skills like that. It's aluminum and from what I remember pretty flimsy (BMW could've made it a little stronger with some bracing behind he plate that sticks down. Good luck
My Ride: 2008 550i DINAN
Engine: V8
Its time we start a Recall Class action. Same here. Welded it first time then it broke again right after I had new front struts installed... $2K. Dealer wants over a $1,000 for the sub frame and sway bar. 9 hours at indy shop its going to be over $2K. I called it a road hazzard and we're in discussion with the insurance company.
I don't think this was engineered well and when the next one snaps in 5 years, I'm filing a lawsuit against BMW or they can fix it for free.
My Ride: 2005 545
My Ride: 550i
I went thru the same issue , but would say it was my fault for hitting a curb on a narrow drive way .. But I went out and bought a piece of aluminum made an exact duplicate of the bracket .. Had my friend thats a certified pipe line welder weld it .. Its been several years since and its held up great , Ive had no issues with the repair .
My Ride: 530i
Engine: M54
As long as you disconnect the battery you should be OK while welding on the car, body shops do it all the time. Heck, I even see a lot of body shops weld on cars with the battery still connected.
My Ride: 550i
Well, I hope to find an aluminum welder that is willing to take the risk. I'd like to take care of it before it gets worse. I might have to replace the whole subframe and reinforce that mounting point before the install. I wonder what that would cost?
umichchris
12-10-2015 01:00 PM
