Active steering reset
My Ride: 2005 BMW 330i Orient Blue exterior Beigh leather interior with Wood trim, Premium package, Steptronic auto, Xenon headlights.
Today i noticed while i was driving my 530i that the steering seems to be of to the left a tiny bit when going straight could this be adjusted by just resetting the active steering at the dealership. I don't think it is an alignment issue because the car has not hit any pot holes or curbs just driven on normal roads. and I did check the tire pressures and adjusted them and sit drives the same. when steering is centered it starts to pull to the left slowly and i did have an alignment 5 months ago and has been only driven 3500 miles since then. what do you guys think?
My Ride: 2008 M5 -- Exterior: Silverstone, Interior: Black. Fully Loaded. That just about sums it up! :-)
[snapback]190692[/snapback]
*Assuming* that this is not a mechanical alignment issue, but simply an Active Steering Reset:
Straight out of the manual:
1) Start the engine.
2) With the vehicle stationary, turn the steering wheel from the straight-ahead position to the left as far as it will go and then back to the straight-ahead position.
3) Switch off the engine.
When you start the engine again, all the functions of the active steering are available once again.
Good Luck.
My Ride: 2004 545i Silver Gray/Black
Step Auto. Sports Package, Logic 7, Cold Weather Package, Parking Distance, and Rear Sun Shades
2002 330ci Titanium Silver/Gray
Step Auto, Sports Package, Premium Package, Xenon, 18 inch wheels.
Originally Posted by CoolTones' date='Oct 29 2005, 05:48 PM
Hi BimmerGuyFL,
Good Luck.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Good Luck.
[snapback]190693[/snapback]
Banned
I don't believe its an alignment issue since i had one done 5 months ago and the car is driven with the utmost care.
