active steering malfunction!!
i have an 05' 545i sport, recently started getting active steering malfunction on my car and it does not go away what can this be??
many have told me my power steering fluid is low, but i am not sure which pump resovir it is when i look under the hood?
I would try checking for fluid 1st. If you look under the hood it will be the resevoir located towards the left (passenger) side of the engine bay, right behind the coolant resevoir. Make sure you use the proper fluid as well, if your low.
GL
so it is the resevoir with the dipstick? if it is than the fluid in their does not touch the dipstick at all unless you push it down! does this mean it is low on power steering fluid?
My Ride: Current rides:
2011 Z4 35i MSport DCT (pictures coming)
2010 535i MSport
2008K1200GT
(Sold) 2001 541i MSport
(Sold) 2007 Z4 Coupe
On the power steering reservior, there is a dip stick connected to the cap so it's imposible to "push it down."
However there is a measuring float in the coolant reservior that you can push down.
Do not get these mixed up as they are two different fluids, obviously.
To make it easy for you, the coolant reservior is rectangle in size (front) and the power steering reservior is circular (just behind coolant resv). Good Luck
e6t, that dip stick thats connected to the power steering reservior is disconnect from the cap does this mean its broken and is it a big deal? is that the same stick richr8 was telling me about with the fill mark half way up?
Dipstick tell you not only if the fluid level is up to specs but also the condition of the oil, so they are very important.
The level indicator on this dipstick only says "max" so as long as fluid is contacting the stick you should be fine, but considering yours isn't connected to the cap, I'd suggest you go buy a new one and check your fluid level. Good luck
mine is black with one max line, the number 20.0 just below the line and other numbers running vertical. hope this helps
