Active steering malfunction 545i
Old 02-03-2011, 08:45 AM
matthewlfd's Avatar
A dead or dying battery may also cause this issue. The car makes sure there is enough power to start as a priority, and may shut down other systems to preserve that initial start power.
Old 02-03-2011, 12:52 PM
krzyschicago's Avatar
Started the car today and the warning light was gone.
Actually, this may be battery related issue, because my battery it is almost dead....
Thanks!
Old 02-03-2011, 01:00 PM
inktoxicated's Avatar
My Ride: 2006 530i mystic blue
i get that once inna while for no reason to. stupid useless crap
Old 02-03-2011, 07:01 PM
asifmughal1968's Avatar
Hey Guys,
I've been reading some of the post as I had the same thing happen to me on the same day on a 2005 530i. Came out and started the car to find the steering wheel cocked (was straight before) and the lights and iDrive indicating the same malfunction. I've tried to reset the car both way (running vs. not running) and no luck. PS fluid is fine as well. Is there a different method for a 530 vs. 545? I'd hate to take it to the dealer for something I may be able to do. Thanks for any advice.
Regards,
Ash
Old 02-04-2011, 01:11 PM
lasvegasguy's Avatar
Originally Posted by asifmughal1968
Hey Guys,
Regards,
Ash
its the same way for all E60's, try it one more time, i had to do it like 4 times!.. this also may be a battery related issue so try checking the battery
Old 07-14-2013, 04:56 AM
FREE100KSECRET's Avatar
My Ride: 545I Sport X5
Model Year: 2007 2003
Engine: 4,4
Interesting,
I had same issue pop up the other day, came back from long trip of 2500 miles, no issues, then parked it for a few days, started it, steering wheel was misaligned by 20% to left and turn signals were no longer shutting off. Checked power steering, looked OK, but it is a bit confusing, generally you fill it to top of line when hot in most cars, but this dip stick has two lines, so should it be at top line when hot? Also have a typical power steering growl when hot and after driving more than 40 miles. Just don't want to overfill for obvious reasons, so should level be at top line when hot?
Thanks,
kammy6000
07-02-2015 05:05 AM
Hyper_545i
07-01-2015 05:07 PM
shervinj
05-08-2015 09:03 PM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: Active steering malfunction 545i
