Active Roll Stabilization Malfunction
Old May 31, 2010 | 07:59 AM
Bimmer4life23's Avatar
My Ride: Silver 08 550 sport
Last night while driving I made a U-turn in front of my house and notice the indicator for the active roll stabilization malfunction was displayed in the instrument cluster. After 2 minutes the symbol went away made another turn and the symbol appeared in the cluster again, I also notice this only happens when I make a sharp left turn. After driving for about 5 minutes and checking the system information in the Idrive setting there's no errors in the service log. Have any members had the same problem.
Old May 31, 2010 | 08:08 AM
rctmthouse's Avatar
possibly low in oil due to leakage. I didn't get any notification from the Idrive but there was some oil leakage and had to replace the unit under warranty before.
Old May 31, 2010 | 08:20 AM
Thanks for the info, but which unit will that a suspension component
Pressure hose
Pressure line
Pressure tube
Stabilizer bar
Stabilizer link
Old May 31, 2010 | 08:27 AM
rctmthouse's Avatar
honestly I do not know that much about car talk but it's the unit right in the middle if you removed the underneath cover. I believe is called the active stabilizer. Had the car lifted up at my uncle's shop and saw oil was dripping slowly from it. I'm sure others here will chime in with more info for you.
Old May 31, 2010 | 12:05 PM
No problem ill check it out before i take the car into the dealer thanks again
Old May 31, 2010 | 02:50 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
more than likely your power steering fluid level is low. the active roll system runs off the power steering pump.
top off with pentosin chf11s
PakiBeamer
Dec 9, 2016 04:40 AM
PelicanParts.com
Meet & Greet Discussion
Oct 16, 2015 03:07 PM
th3h1ghlander
Oct 9, 2015 07:40 AM
benski
F10 Discussion
Sep 16, 2015 07:10 PM
fifthofjac
Aug 30, 2015 07:08 PM
