Active Roll Stabilization error
My Ride: 530xi
Hey guys,
New to the forum mostly doing searches but recently purchased a BMW 530xi 2007.
The KOMBI/Cluster was broken in it so bought as is, was able to get my hands on a cluster off a 545i BMW 2005 and transferred my memory chip onto it so I get the right odometer/vin displayed.
My issue is after putting the Cluster on I get the following error:
A3B3 Active Roll Stabilization error. (Error is in the Kombi unit)
My 530xi has a DSC button but does not have active steering and does not have active roll stabilization option (just regular sway bars).
I've read up on the error and it doesn't sound like I should even be getting the code, or can a bad power steering pump even if you don't have active roll stabilization option / Dynamic drive cause the error to come up?
Or maybe it's the cluster, I did code it to the car so the fact the error is still coming up I'm thinking maybe it's related to something else like a bad power steering level sensor? What can cause that error?
Thank you!
Thank you!
My Ride: 530xi
The 545 Kombi had a few DSC functions enabled that wouldn't change even after DEFAULT coding.
Since my car is a 530xi that had a dead cluster, I got another 545i cluster for free, transplanted the memory chip 35080vp for ODO/VIN. Then default coding didn't do anything to code cluster, still kept getting the errors and airbag.
Went ahead and pulled the TRC file with NCS and disabled manually in the 545i options my car doesn't have so just disabled in Kombi.
Now airbag / ARS feature that I don't even have on this car no longer come up on Kombi or CCC
My Ride: E61 530d
hi, wot did you disable in the trc file mate, i have the same problem on my e61,( A3B3 Active Roll Stabilization) none original kombi, regards thanx
