Accurate rpms,speed etc.
#31
Very interesting!
I have to check this out when I go and fetch my car from the company garage tomorrow or Sunday.
I where out partying last night (I leaft yesterday on a short fall vacation) and the car is still downtown
#32
My Ride: 525i SE Black Saphire, Black Dakota Leather, 116 type alloys
Originally Posted by Stranger' post='205117' date='Nov 30 2005, 05:35 AM
You need to get your VIN number. I remember menu 1 once you get into this secret menu will show the last 7 digits of your VIN. Assuming it is B3XYZAB, I simply do X+Y+Z+A+B. Then whatever this sum turns out to be I just go to menu 19, and enter it there. As you can see, the max of X+Y+Z+A+B is 45 (all 9's). You can also try circulating through each of these numbers in menu 19. There are only 45 of them.
Sorry but I'm a bit slow - how do you work out what number the alpha characters are? (Why are they 9's?)
#33
My Ride: Nothing to boast about!
#34
[/quote]
Thanks - I said I was slow! If I'd bothered to look at my VIN number first, I'd have realised they were numbers. Anyway, now that I know, I'll go have a "play".
#35
My Ride: 530i R6 SMG M-Sport; Silver Gray & Gray Dakota; Comfort Seats; L7; Adaptive Xenons; Advanced A/C; BlueTooth
Originally Posted by streak' post='73046' date='Dec 28 2004, 02:05 PM
Hold down the km reset button and turn the key to first position (radio on) immediately release the button.
You will see a small display where the time/temp etc. usually appears.
Sequential presses of the button steps through this menu ie. 1,2,3,4,5 etc. up to about 21.
Mine goes trough 1.0 to 1.7. How to jump to second level?
Add up the digits of the numbers printed on your window.
Please clarify.
Go to position 19 on the menu and wait a second or two. Under lock you will see a position to enter the calculated number which you do by sequential presses of the button.
Once you get to your calculated number stop pressing the button and wait.
Calculated number?!
Menu goes back to position 1.
Now toggle through to say position 7. Once you get there wait a couple of seconds and you will then see 7.1, next press shows 7.2 etc. etc.
You will see that it displays, rpm, fuel consumption, battery voltage, current speed, core temp. etc. etc. etc.
Each menu has something different some meaningful some not so meaningful.
Those of you that understand German may be able to translate.
Good luck
Streak
Please clarify.
Calculated number?!
Good luck
Streak
#36
Please clarify.
Calculated number
I cannot get past 1.0
And i see nowhere to add anything up or put anything in? If i click through it just goes from 1.7 back to 1.0 and then keeps going through....
Please clarify.
Calculated number
#37
Once you get into the menu, it shows something like B123456 for example. For me the "calculated number" is the sum of the last 5 digits of this. So, in this example, the calculated number would be 2+3+4+5+6 = 20.
To change to the next menu, you press and hold the knob until you see 1.-- (something like that). Release the knob but press it again before it goes to 1.0 again. You should be in menu 2.0 now. If you leave it long enough, then you will be cycling in submenu of 2.0 when you press the knob. I hope I am clear enough. So to change the menu, you continue to press quickly.
You must unlock the menu first in order to see all the rest of the menu. Go to menu 19. You will see something that says lock, and the last line is something like "code?" which will show up after a very short delay. Once it shows up, press the knob continuously until you see your "calculated number" shows up. Then stop, and let it go back to menu 1. Your menu would be unlocked now. Remember, once you see "code?", you must key in your calculated number. If not it will go back to menu 1 on its own.
BTW, my avatar shows what you will see in menu 2. You don't need to unlock the menu to see menu 2 though.
#38
#39
Yes pasquale that's correct. Once in menu 19 and in unlock mode, each time you press the button the count advances by on so 20 presses for 20.
I often make use of this hidden menu for various reasons. The latest was to monitor battery voltage before and after charging the battery after the car sat for a month while I was away.
#40
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following:
530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman.
Mods done:
� Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110
� Authentic HAMANN REAR SPOILER Item-No.: 10 060 130,
� Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120
� Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122
� Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216
� Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber ,
� Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060
� Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117
� Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111
� Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409)
� ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports)
� ///M pack rear
� HAMANN ECU upgrade 265 HP 608 Nm.
most improtant:
�real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3
� CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows).
� Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20"
Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange
DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315
10.5 J x 20 only RA Item No.: 91 207 625
Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20
� Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125
� Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM
� Authentic HAMANN SIDE SILLS Item-No.: 10 060 120
� Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235
� Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange)
� Authentic HAMANN sports mirrors (all functions)
!!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!!
E60.net Clings
Still to do list;-):
� Our Hobi's camera system from : ww.switchchange.com).
� Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
[quote name='streak' date='Dec 28 2004, 02:05 PM' post='73046']
... is it possible that I have only upto 8???
so no 21st?
and when I try to press that further than goes back to the first...
WHich numbers from the windshield???
thx and sorry for asking but cud screw sg.
so no 21st?
PelicanParts.com
08-10-2015 01:55 PM
