Accurate rpms,speed etc.
I displayed the hidden menu on the instument cluster and then unlocked the menu.
The resulting displays then showed accurate rpm's, actual speed, test display (to make sure that all the warning messages are working), reset, consumption and many more which I did not understand.
These displays work while driving the car as well.
Interestingly the rpm's do not change at all with the aircon on or off which seems different to those of you with petrol cars.
I am sure how to do this has been discussed before so I wont go into detail again unless specifically requested to do so.
Cheers
Streak
My Landrover Horror Story
Cheers
Streak
My Ride: 535d Titanium Silver, Black Nasca Leather, Servotronic Steering, , De-Chrome, Bi-Xenons including Headlight Washer Jets, adaptive headlights, Advanced A/C, Auto Dim Interior & Exterior Mirrors, Electric Folding Mirrors, Front Centre Sliding Armrest, extended lights package
Yes tell us more how do you display hidden menu? thanks
[snapback]73022[/snapback]
Hold down the km reset button and turn the key to first position (radio on) immediately release the button.
You will see a small display where the time/temp etc. usually appears.
Sequential presses of the button steps through this menu ie. 1,2,3,4,5 etc. up to about 21.
Add up the digits of the numbers printed on your window.
Go to position 19 on the menu and wait a second or two. Under lock you will see a position to enter the calculated number which you do by sequential presses of the button.
Once you get to your calculated number stop pressing the button and wait.
Menu goes back to position 1.
Now toggle through to say position 7. Once you get there wait a couple of seconds and you will then see 7.1, next press shows 7.2 etc. etc.
You will see that it displays, rpm, fuel consumption, battery voltage, current speed, core temp. etc. etc. etc.
Each menu has something different some meaningful some not so meaningful.
Those of you that understand German may be able to translate.
Good luck
Streak
Good luck
Streak
thank you for your prompt reply
