ACC deactivation
Looks like there is a simple way to deactivate the active part of the ACC.
On a german language forum about E60 I've found the following text:
"Um vom ACC in den DCC-Betrieb (Dynamic Cruise Control) zu schalten, musst Du die Abstandswippe am ACC-Hebel f?r 3 Sekunden nach oben (..oder unten, funktioniert beides) halten.
Jetzt regelt das Fahrzeug nicht mehr auf den Verkehr und auch die 180km/h-Begrenzung ist aufgehoben :-) ==> Hurra!"
Which (with my little german) concludes that keeping the switch (or the lever?) of the ACC up or down, more than 3 seconds, will deactivate the active radar part of ACC and also the limit of 180 km/h. To activate it back, just a quick push of the same lever, up or down.
Can someone confirm this information?
My Ride: F02 LCI Individual
Model Year: 2013
It definately doesn't work on ACC.
I just tried it!
ACC can't be used as CC!
I was pretty sure about it, since I have never ever heard about that trick before, not on the forum, not in Munich.
I just tried it!
Model Year: 2013
Yes, your translation is correct. He claims it can be deactivated. If he is right, that is a bug.
The radar is implemented into the CC, therefore it allways works together.
