AC - Water Behind My Dash
Just realized today that something is clogged with my AC. I just had my microfilters replaced and they still look clean and clear.
When I turn up the fan, it sounds like the air is running through a bucket of water. I also get water blowing out of my vents. If I turn sharp down the road, I can hear water sloshing behind the dash. I believe something to do with the drainage is clogged. Any ideas on where to look or what to do to clear things up?
2004 E60 530i
2004 E60 530i
It's either a blocked water drain for the AC compressor, or the heater matrix has blown. The first is cheap to fix the second expensive because you have to remove the whole dashboard to get to the matrix. You should have it checked by an indi or BMW.
Had this same issue. Unplugged the drain behind the passenger front wheel located behind the plastic wheel well protector. Didnt help. Put the car on a lift, removed both under car protection panels that cover the transmission and oil pan.Unplugged both drains that are located on each side of the transmission releasing lots of water. Both rubber bug and debri flappers were not opening. Cleaned them both out and cut a V with wire cutters in the bottom of the rubber to drain the water if it ever sticks again.
Vman33
Mar 14, 2022 04:43 AM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
