AC lags in getting cold..........
My Ride: f10 535d M sport e46 330cic vert
Model Year: 2015
Hey guys, I was wondering if anyone else has this issue........ When my '04 530i has been sitting outside for a few hours or more in the hot sun, it takes around 15 to sometimes 20 minutes to blow cold air. Once it starts to blow cold, it get really cold, it just take a long time to get there! I have had it checked out by the Stealership and ARA airconditioning and the both said they couldnt find anything wrong. The freon is fully charged and the compressor and everything check out fine. ARA said the cars only accept 1.25 pounds of freon and that is why it takes so long to get cold when the interior is hot. Does anyone else experience this? Thanks, Brad
My '08 535xi's A/C works properly, but it's not the most robust system I've had. I'm not sure if the controls have changed over time, but if possible you should have the system set to engage recirculation (Max A/C) automatically. Also, though I apologize for stating the obvious, it doesn't hurt to roll down all your windows for a minute or so to get rid of superheated air.
My Ride: 2008 550I M Sport, Premium pkg, Logic 7, Sport Automatic Trans, Paddle Shifters, Nav, Comfort Access, Rear Shades, Satellite, PDC
I just brought my 08 550 in for the same problem. SA mentioned that they have issues with the compressors and are seeing many of these in for this problem. Fortunately, it's under warranty. I'd hate to see what that would cost.
My Ride: 08 535i stock.
wifes car 07 x5 stock
I have an 08 535 and i have the same exact problem. I love it but this is a major problem because i live in such a hot humid area. If you find out anything please let me know. thanks.
My Ride: 05 545i
mine, 05 545i has same problem. i have my own auto shop I tried to find the problem but everything looks like OK but today
I found a aticle from alldata.
it says that it is compressor. once you replace ac compressor It sould be OK.
if anyone wants to read the bulletin, plz leave a message with your email address I will send the article. Thanks
I noticed my 08 535 was lacking as well when I would get in it after it sat out all day in the sun at work. After driving a few minutes it would blow cold. I started putting the sun reflectors in the windshield while it was sitting out and this made a big difference. Now it's blowing cold much faster. I assumed it was due to the piping heating up from sitting in the sun. I will also have the windows tinted soon and I'm thinking this will also help it out. When the car is in my garage, it blows cold instantly.
My A/C blows cold almost instantly. However, even on recirculate it's slow to cool down the interior - especially for back seat passengers.
Even with those rear vents wide open, the working class in the back seat always complain while I'm making ice in the first class seats
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
My Ride: 2006 E60 530i
What are your climate settings set to?
If you click Left from the home screen, you'll come across the climate page, where you'll have 1-4 bars, either white, red, or blue. If they're red, that means that the car is setting the vents to heat your car (Which you don't want), and if it's white, it means its neutral, and blue stands for cool. I usually set mine to the max of either setting when it turns winter/spring/summer, depending on the temperatures.
I find it counterintuitive that BMW put this menu in the iDrive, as on the new F10's, there's a dedicated slider for it.
